Please Help ME!!!! 2000 Explorer wont start | Ford Explorer Forums
norse74
2000 xlt
I have a 2000 explorer xlt and there appears to be a problem with the electrical system. I replaced the battery and the alternator/starter are fine. It will not start on random times and I would jump it and it would work fine, but now it won't even start with a jump. When I jump it nothing will come on, not even the power door locks etc. If it is not the battery can it be the main relay? Part #? Any help is appreciated!!
if you insist it is not the starter check your ground points off the battery. if even a little loose will cause this
Sounds like a connection problem. Check your cables for corrosion. Keep in mind that cables can corrode from the inside, so they may look fine externally.
you guys were right, works fine now. I feel stupid, and thanks a ton for the tip.
