Please help with no Power Steering!! | Ford Explorer Forums
BAYDOG
Phelps NY
95 Sport
I was wheeling last week, and hit a cut off tree pretty hard with the right front tire. Bad enough that I ruined a upper Ball joint and bent the spindle ( knuckle). Well , the ball joint is replaced, and the I got a used spindle, now the only thing that isn't working is the power steering. No fluid leaks at all, lines all seem fine, and when she went back together, the tie rod all lined back up to with in a 1/4 inch front to back. ( I know I'll need a front end alinement). But the pump does'nt seem to be working at all, no whinning when I try to turn the wheels. Any clues guys??
