bpopp
- February 21, 2007
- 99 Explorer 4.0 SOHC
Please Help with Rough Idle - Solved
I have a 99 Ford Explorer w/ the SOHC engine and 110k miles. This is my second engine (first was cooked by notorious timing chain tensioner). The engine was running great when my auto transmission went out about a month ago. The cause of the transmissions demise was most likely a wiring harness getting busted up and coming loose enroute. I got a big jolt shifting into 3rd and a blinking OD light. Had the transmission replaced w/ a junker and they rewired the harness. They also replaced the AC compressor (so I have air now).
Unfortunately, now I have a very rough idle (wasn't there prior to transmission failure). Here's what I've done/noticed:
* Idle bounces between 400 RPM and 1400 RPM every 2 or 3 seconds. On the low end, it shudders and shakes the entire truck.
* Have DTC P0171 and P0174 (lean bank 1 & 2)
* If I unplug the MAF, my idle clears up substantially. I cleaned it w/ electronic parts cleaner, but this didn't seem to make any difference.
* I also replaced the MAF w/ a new one, but as soon as I plugged the new MAF in, rough idle returned. Unfortunately I did not think to reset the computer before removing and returning the new MAF.
* The idle is only rough in Park and Neutral. In drive or reverse it clears up substantially. Still not perfect, but the bouncing/shuddering goes away.
* Replaced the DPFE/IAC w/ parts found at a local junkyard. They obviously aren't guaranteed to work, but made no discernible difference.
* Checked the fuel pressure and it's around 60PSI.
* Tried using propane to search for a vacuum leak. Couldn't find one.
* Don't hear the notorious death rattle yet, but it's been very warm here.
* Rough idle exists even w/ the AC turned off.
* Idle does not improve or degrade as the car warms up.
* Engine runs okay at higher RPMS, but it seems weak on inclines and doesn't seem to have the power it did a month ago.
I tried taking it back to my mechanic. He said he was getting a misfire on a couple cylinders. Changed a few plugs out and said it was fixed. He also said that one of the injectors was "acting funny" and that I should run some injector cleaner through it (which I did). The CEL was still on and it didn't seem any better.
He assured me it was nothing he did, but I'm wondering if he possibly switched a couple wires around when he was wiring that harness back up (it's the harness that connects the transmission to the computer). I think there's also an oxygen sensor back there that connects into the same bunch of wires. Unfortunately it's on top of the transmission so I think it would be very hard to get to without dropping the transmission.
Anyone have any ideas? I'm ready to light this b**** on fire. I love my Explorer, but this is so frustrating and I'm worried it's going to damage the engine having it running so rough.
I have a crappy scanner, but am contemplating buying a OBDII Automotive Scan Tool to see if I can get a little more information to work with. There are about 10 different causes listed under the DTC of "lean bank".
