Please help | Ford Explorer Forums
Please help
EXPLORER04
Buffalo, NY
04 XLT
My x keeps blowing the 30amp ignition fuse under the hood and can't figure out why. Please help. Thanks
Get the owner's manual - see what system the 30 amp fuse controls and check the system with a voltmeter for resistance/continuity.
Posted via Mobile Device
its for the ignition system
Use a meter and check for a short to ground. If shorted to ground the resistance between that circuit and the Batt Neg will be shown in Ohms. In a correctly working system it should be O.L. (Out of Limit) or on a very cheap meter it may say 10,000 ohms. If it shows 100 ohms or .5 ohms for example then there is a short to ground. The most common cause is a wire that has rubbed through it's insulation and the copper is now touching a metal surface. This is where a wiring manual comes in handy.
