backroads
- April 19, 2004
- Seattle
- 06 LTD 4.6
I finally got around to changing the plugs on my 2006 4.6 v8 Limited,95000 miles. So my plan was to go for it, and if a plug broke I would just order the Lisle tool and let the plugs absorb more PB Blaster for a few days. So I loosened all the plugs 1/4 turn and sprayed PB down the holes and let them soak for 24 hours. The Pb Blaster level never went down so I loosened them another 1/8 and left them for a couple hours.
Then using an impact driver I remove #1 and sure enough it broke. So I ordered the Lisle tool and 3 days later I removed the rest of the plugs. 4 of them broke, and the Lisle tool did its job and an hour later I was done, fired up the motor, ran fine and there was smoke from whatever PB Blaster was in there even after cranking it over before installing the new plugs to blow out excess PB.
My theory about the broken plugs is that they usually break when you first crack the plugs 1/4 because 1/4 turn is enough to break the plug below the threads.
Then after about 25 miles the cel comes on and its P0430, my theory as to why that happened is because PB Blaster may have contaminated the cat, or an 02 sensor.I cleared the code twice but it comes back after a while.
Thoughts guys?
Thanks
BRoads
Thoughts guys?
Thanks
BRoads
