PO304 Any Advice?,,,,, | Ford Explorer Forums
eckerd_explorer
St. Petersburg Florida
2000 XLT 30" XTR's
so this code has been popping up for a while now. i've replaced the egr valve, the DPFE, and the plug. i'm still geting a pending PO304 code(#4 misfire) i've searched the site and saw that the # wire rests on an egr line causing a little too much heat which may lead to the misfire. could that be the prob? any help would be great. thanks. :thumbsup:
Yes, it's probably the wire. I'd replace it, or at least check it with an ohmmeter. (Normal resistance is 6K-12K ohms per foot). Also check/clean the #4 coil pack terminal.
