poping sound | Ford Explorer Forums
poping sound
lifeguard379
sacremento,ca
93 eddie bauer 2 door
hay i just replaced my rad bushings, and it stil pops when braking and when backing. any thing will hellp thanks
dos any one know what this culd be i serched and found nothing
Mke sure you torque the bolts (1 1/8") that hold the radius arm to the axle housings.
Anything else loose? tie rods, shocks, sway bar, ball joints, etc.
Can you better isolate the clunk? front, rear,
i just instaled a 2" lift but it did this befor that. the old bushings wher realy bad and dintid the crosmember culd that be it?
dose any one els have any ideas? thanks
How did the radius arms look? I've heard that if you drive too long with bad radius arm bushings you can damange the arms due to metal on metal contact. IF that's the case, then the new bushings may not seat properly.
the x member had a desent dent in it. i will try to get a new one thank you.
