Post body lift driver side higher than passenger? | Ford Explorer Forums
snake_fl
Largo, FL
2001 Ford Sort Trac
Like the title says. Surprisngly the driver side sits an inch higher than the passenger, which I thought maybe with the gas tank on th driver side then it would sit slightly lower but it's not in this case. Also this is measured from the back but when I measure it from the front then it's about half an inch higher.
Could this be due to the leaf springs in the worn out as it is and I just never noticed it till now? Anybody had similar problems? Everything I did on the performance accessories body lift seem on point
