WoodsBuggy3
- June 6, 2003
- Akron, OH
- 92 4wd Sport
Ok, did a search didn't really find anything that is quite like my prob, so maybe you guys can help me out. 92 Explorer, 175K, lately the fuel pump has been making some noise so I replaced it and the fuel filter, at the same time I replaced the exhaust with a cat back Flowmaster, kept throwing CEL's with tons of codes varying from coolant temperature sensor to rich oxygen sensor, and a TPS, and some other codes that were not in my book. Any how put a new TPS on and a coolant temp sensor, ran great, had more power than ever before almost felt sporty. Still getting CEL's, so cleaned MAF bought a K&N drop in filter, drilled holes in Air box, at WOT it would totally bog down, and barley hit 65, back off a little and it would take right off, just for the heck of it I duck taped my holes in the airbox I drilled, now it does not bog near as much but still does, and still getting CEL's, So I replaced the O2 sensor, ran a little better yet still getting CEL's and bogs, also exhaust smells, and gas mileage has been terrible, under 200 miles on 19 gallons. Ran codes again and its coming back saying O2 is sensing a rich condition. I apologize about this being so long, but I'm just stumped, Oh yeah idles also erratic, sometimes idles perfect other time its at 1500 till you punch the gas then it will drop down, then other times it just lopes from about 700 to 1000rpm. I'm going out on a shear guess, but the next thing I was going to replace is the fuel regulator, does this sound like a feasible solution, or is their something else I should do??? I pulled codes tonight and I'm getting a 173 and a 179 if this helps.
