Power steering pressure hose - 2nd seal? | Ford Explorer Forums
SoHK_alumni
Tampa, FL
5.0 V8 2002 Ranger
I've picked up a leak in the power steering pressure hose, right at the p/s pump on my '96 Expo 5.0.
The leak is between the center tubing and the outer fitting that screws into the pump.
The nylon seal for the outer fitting is commonly available, but is there a 2nd seal between the fitting and the inner tube? And if so, how to replace?
