Power window help please. | Ford Explorer Forums
gmshifflett
charlottesville,va
2002 explorer
2002 explorer . had problem on drivers door couple months ago. took panel off and cables all broken. new reg/motor and fixed that. i figured same problem on pass door but its not. i took reg/motor all out. i can raise the reg. with my battery charger,reverse leads and it lowers,all seems good there.i can also send reg. up with both switches,drivers side and pass side,but not down.i tried another pass side switch-didnt help.checked wires thru door into and under dash. they are good, nothing broken. any thoughts? thanks very much.
thanks for your welcome and moving me where i should be. i will look for that schematic also. thanks.
