Problem when starting only. | Ford Explorer Forums
Tango40
Blairsville PA
1995 xlt Explorer
95 4.0 xlt 152000 miles.Just started having starting probs today,here are the symptoms.turn the key starts fine rpms go up then straight down and sometimes shuts right off or just about to shut off.if i give it gas while it is ideling then let off the gas the rpms go right back down almost shutting off again.does not do it at stop lights,stop signs,only when i start it.check engine light comes on some times not all the time.Over the last 12 momths I have new Fuel pump,new battery 6 months ago and new fuel filter 2 months ago tyring to elminate them as problems.Thanks for any help guys.
Sounds like a bad IAC valve:(
