Problems with my front diferential | Ford Explorer Forums
Renez
Philadelphia
2003 ford explorer limite
I need some tip and help ...
i have a 2003 ford explorer limited 4.6 awd ...
I started having problems listening to a loud noise as if the gears in the differential were skipping, in addition to pulling the wheel to the left, later the squeak of the noise returned and the alignment of the normal wheel returned, the mechanic told me that my Differential was damaged, I have changed it, but it sounds as if something is holding it and already running it pulls me to one side and then to the other it is very unsafe, I decided to remove the draft shaft and it runs normal but I want to fix the problem to continue having the awd, could someone help me please
What exactly number or code for my differential
