Pulsing day time running light/fuse mess | Ford Explorer Forums
trailblazer295
Ontario
02 Explorer Sport
Hey Guys
Recently I noticed my day time running lights pulse(flicker), the low beams are constant. I have checked the relay box under the airbox which had no affect on the lights. Is there any other relay's that control the running lights? Also I don't know if its connected but looking at the manual and the fuse location there are alot of discrepencies, fuses are missing or extra, fuse values are commonly higher or lower than what the manual says. It seems I will have to bite the bullet and visit a dealer to try and fix this issue. Any help is appreciated.
Scott
I have read about a lot of issues with this happening.
However, knowone has posted a solution to their previous postings. Anyone resolve DRL flickering?
DRL's don't use and are not connected to the low beams.... they use the high beams. Odds are your DRL module is fubarred.... but check the voltages and grounds at the module to ensure it isn't a bad connection before wasting money on a module.
Where is the DRL module in an 02 X sport? I have checked behind the drivers headlamp and see nothing.
