Question and Input please | Ford Explorer Forums
KeatsCYN
Albuquerque NM
94 Explorer XLT
Ok so my buddy has a 86 ranger he has a 6inch skyjacker lift on it.
Hes trashing the truck and said I can have the lift for 200 bucks.
Now would that lift be able to be put onto my 94 explorer?
Or do you think the lift is worth less? More? Hell i dunno lol
Whatever is in the rear definatly wont work but you should be able to get 6" with a spring over. As for front I'm not completely shure I do think it may work. But the condition of the brackets, whether or not it has extended arms drop pitman arm , superunner steering etc, etc... should play into your decision. If you have to replace brackets you may as well buy a new kit. Pics would be helpfull.:confused:
The rear springs will fit, but the lift height won't be quite the same on the Ex (you'll need to flip the centering pins over on them too).
I would just do a rear SOA on it. The front stuff all fits exactly the same.
Ok it is ran with drop down brackets ill have pics later this week of what im buying.
Then ima buy all the stuff from him.
So how hard are these to install?
And to do a SOA in the rear?
The front parts are all the same and will work out well. They mostly bolt on over top of the factory parts - in some cases, you may have to do some other work, but you'll know that when you pull the parts off of the Ranger. One difference between the two is that the Ranger has a Dana 28 axle and the Explorer has a Dana 35 -- the brackets are the same, however. Also, the Ranger will have a sway bar that mounts insde the radius arms (go back to the frame) while the Explorer will have a front of the axle mounted sway bar. Dump the Ranger bar -- the Explorer setup is much better, and you can make disconnects for off-road use by replaceing the bolts with pull-pins where it mounts to the axle.
Out back, you won't need any of the Ranger parts except the shocks. What you will have to do is to cut off your leaf spring pads from the axle, and then weld on some new ones on the top side. Make sure to measure your pinion angle before doing the cutting and welding so that you can duplicate it when you weld on the new mounts. This is very easy fabrication work, but you will need to have or have access to a 4" grinder, a couple of cut-off wheels, perhaps a cutting torch set (makes it easier to get the old brackets off) and a welder of some kind, preferrably a MIG.
I just got done welding new mounts on the Dana 60 I'm sticking under my 86 Ranger - here's a pic of how it works:
You get the extra 5.5" lift with stock springs simply by setting the springs on the other side of the axle tube. Make sure you lengthen brake lines! I use newer model Superduty lines up front (they are all the same -- just pick a year like 2003) and re-bend the line out back (and/or add an extension line).
Awesome
Thanks so much!
