R&R Transfer case - what else to replace? | Ford Explorer Forums
masospaghetti
Huntington Beach, CA
98 XLT, OHV, 4D, 4x4, 5M
Hey all
I'm removing and replacing my transfer case with a rebuilt unit from TC Express in Spartanburg, SC. After I drop my old one out, any seals or gaskets that I should be replacing? (Output shaft seal, etc)?
Thanks all
1998 Explorer, 4.0 OHV, 5-speed manual, 4405 TC. 200,500 miles.
Hey all
Thanks all
I'd inspect it but I don't know if output seal can be replaced without removing shaft
Maybe consider replacing the u joints mostly for mileage sake and its already off...
Also would be a good time to replace pinion seal if needed...
The only gasket is the one on the extension housing, it is paper, use a thin skim of RTV on the paper if you like. The seals should all be new on your reman unit, so just the paper one at the extension housing.
