Yesterday morning I've noticed some yellow-ish fluid that seemed to drip from under the truck onto the white snow beneath, and my first guess was that it was either prestone or possibly fuel (I filled up to the very top just minutes before). After inspecting the truck for more leaks later in the day, I came to to the conclusion that I was not leaking anything, at least visibly.
I nevertheless spoke with a professional mechanic (with many years of experience), just to find out what it might have been. He had told me that many smaller prestone leaks can be eliminated by removing pressure from the cooling system, and that can be achieved by cutting small notches in the lower gasket of the radiator cap (the smaller round gasket) or cutting the cap spring - this supposedly brings pressure to 0, and since the system is not pressurized, hoses do not swell up and don't leak. He stated that he runs all his vehicles (new and old) like that for many years, and has never had a problem. The only apparent side effect is the fact that the heater takes a bit longer to blow warm air.
I just did that mod to my Ex, and will monitor it closely... If anyone has any suggestions or remarks about this, please feel free to voice your opinion. I don't think my Ex has any leaks, but the idea of running a no-pressure cooling system to preserve the hoses and gaskets seems to make sense to me, even at the expense of waiting a bit longer for heat to kick in during winter.
[/QUOT The only reason cooling systems (in gasoline engines anyhow, diesels are another story for various reasons) are pressurized is to raise the boiling temperature of the coolant. A slightly 'stronger' mixture of glycol/water, i.e. more glycol, will do the same thing to some extent and negate the need to pressurize the system. I have been removing the lower seal on radiator caps on vehicles from the 70's to present vehicles and have suffered no ill effects; time for engine to warm up and heater to work is not changed noticeably.
