danlong
- October 16, 2003
- Gainesville, FL
- 2001 Sport Trac 2wd - V8
Has anyone used the radius arm crossmember from www.suicidedoors.com ? When I removed my driver side radius arm this weekend to replace the bushings, I found that a large chunk of my crossmember had broken all the way around the hole where the RA goes through. I need to replace the crossmember now, and am debating on a factory piece or using the one that Jason sells. I'm pretty sure that the Ranger and Explorer use the same onel, right? If anyone has used the custom one, are there any pro's or con's to it, aside from the extra ground clearance it gives?
