cguerra
- August 25, 2010
- Laredo, Texas
- Ranger 2000 XLT,4Cyl,5Spd
Hi, I’m trying to look for some information on a few problems with my clutch system on certain situations in my Ranger 2000 XLT, 4Cyl., 5Spd.
If I drive for a while in a stop and go high traffic commute for 30-45 minutes I’m starting to have problems shifting into 1st gear, I need to double pump and press all the way to the bottom or press hard the shifting stick to be able to engage, the problem will get worse as time passes, if I get out of the stop and go traffic and drive in a highway at normal speed the problem goes away even in the next stop light, seems like the problem is when the clutch system gets extremely warm during a long period of time.
The other problem I start experiencing is in a cold condition, I will notice small difficulty shifting any gear, after driving for a while the problem goes away.
I checked the fluid level and is normal, also no sign of leakage.
Any ideas what could be the problem, a Master or Slave cylinder maybe?
Regards
Regards
