rickman
- January 31, 2008
- Raleigh, NC
- 2003 Ranger
I've read so much stuff on the web about transmissions, starting to get a little
'96 Ranger, 3.0, 200K miles showing, don't know history of truck or trans. Runs good but after driving about 5 minutes (warms up), OD light flashes, shifts hard, shudders, and won't go into OD. According to shop, bad 3rd solenoid.
Replaced solenoid and put in a Transgo shift kit at the same time and adjusted bands. Now I only have 1st gear, (linkage is hooked up correctly). Also, no reverse unless you start it up and quickly shift to "R", it will back up for about 2 seconds then stops pulling. Any suggestions??
