Rare center brake hose ,it has a junction box for the left and right rear brahes and bolts on to the axle,bolt is completely stripped.Is this a banjo | Ford Explorer Forums
Steven dellucci
Hudson
1995 mazda b2300
So I'm replacing the rubber hose with the junction attached to it,it bolts right to the rear axle.the bolt in there is completely stripped, I've tried pb blast,rachets,vice grips,cold chisel and hammer,it's not budging. Is it a banjo bolt? I don't see any washers under it. Can I cut the head off ,drill and ez out it? Thanks in advance to reply. 1995 mazda b2300 4x4
If you’re having that must trouble extracting it, I’d be leery of an extractor. If you’re replacing it I’d try some heat, as little as I like to use it. Have a welder?
