C420sailor
- July 29, 2008
- Long Island, NY
- 98 XLT SOHC, 99 EB 5.0L
'99 5.0L AWD. Runs smooth as butter, drives and shifts great.
Since I bought it (~600mi ago), it's had what sounds like a gentle, quiet rattle while driving when you close the throttle. Silent until you let off the throttle, then you'll hear it as RPM slowly decays through ~1700-1400, then it's gone. At first, I thought it was a belt idler or tensioner bearing that was going south, but I replaced all and the noise persists. Lubricated the cam synchronizer, no change. Can not duplicate while stationary, only while driving. Sounds like it's coming from in front of me, not the transmission. As soon as you ever so slightly crack the throttle open, it stops.
The above makes me think it could be vacuum related (closed throttle, under load)? Braking doesn't make it better or worse, though.
No codes, no other issues. Thoughts?
