Rear bumper compatability between a 2 dr and 4dr? | Ford Explorer Forums
2k1_V8
Philadelphia, PA
2001 XLT V8
hi all. I have a quick question. Does anyone know if a 2000 2 door sport rear bumper can be swapped onto a 2001 4 door XLT?
At first, I thought so, because they look identical from the outside. When I looked underneath, the area where it bolts to the frame looks a bit different.
any info would be appreciated.
thanks
you may have to swap the brackets from bumper to frame to work, but I think the bumper itself is the same.
Might need to swap the brackets also, but it should work.
Considering there is no difference in the body lift kits between the 4dr and Sports, I'd assume the bumper brackets would be the same as well. Right? I'd think the bumper would bolt right on.
