Rear Diff Fluid Change Question | Ford Explorer Forums
2000co
Englewood, co
'05 Mountaineer V6 AWD
Getting ready to change fluids and got several questions. Thanks for your help in advance!!
Rear diff –
How many bottles of 75-140 gear oil I need to buy? Per the owner manual I need 3.5 pints which is 2 bottles, does that include the 1 pint I need to add to the wheel speed sensor?
Front Diff and T-Case – any special instructions on how to do the fluid change?
You're covered with the 2 quarts. Just did mine a few weeks ago. That sensor is just a bit tricky to locate. It's up there though and someone had a nice pic in another thread.
How much oil you put before it start flowing from the fill hole?
I was thinking to lift the back of the truck when it's start flowing and add the pint from the fill hole insted
I got one quart plus a 1/4 of the second quart to reach the fill hole. Then the additional pint from the sensor port. I don't recommend tilting the truck to add the additional amount.
Any special instructions for the t-case and front diff?
T case is pretty straight forward. Front dif does not have a drain plug, so you either have to pop the cover off or suction the old fluid out. I chose to suck it out because removing the cover would be a real pain in the ass with a cross member in the way.
