rear-end problem | Ford Explorer Forums
rear-end problem
  • Thread starter Thread starter gensic11
  • Start date Start date
G
gensic11
I noticed when i get a lot of weight (carrying a few guys in the back seat.. etc) anytime i hit a bump my back end squeaks real bad.. could it be the shocks? it only does it when theres a lot of weight in the back.. and if i hit a hard bum without weight in the back..
Either the shocks or the leaves rubbing together. Either way I wouldn't worry about it unless your rear shocks seem worn out.
if the shocks are original then they are probrally worn out but you could try spraying some lubl like wd40 into the leaves and shackles
