Brian Jordan
- March 28, 2006
- Ontario, Canada
- 2010 Limited V8
Anyone else having this issue? Only when going around corners going into/coming out of a driveway, or over rougher road surfaces I get a "chirp" from the back tires. I rotated the wheels the other day and also notice an abnormally high measure of wear on the inner portion of the tire tread.
Is this a common occurrence with the IRS set up n the 3rd and 4th Gen models, or am I experiencing other issues? The rear suspension seems "tight" and with the tire off the ground at least, there didn't seem to be any slop in the rear wheel bearings, or suspension components?
What gives? What should I be looking for? Is it simply in need of an alignment, or is there a worn suspension component I'm missing, not easily found with your basic circle check?
