Recoil Rob
- April 5, 2008
- 2002 XLT
I've been dealing with an intermittent "sticking pad" problem on my 2002 ever since I replaced my rotors and pads with EBC performance parts.
The left front wheel will be fine until I have braked heavily a few times and then it begins to stick.
The rim will get hot but when it cools down the wheel will spin freely.
I spoke with a mechanic how tells me if it were the Master Cylinder or ABS it would be all wheels, not just the one, he says change the caliper.
Recommendations for a decent aftermarket caliper? I think someone here once recommended the NAPA semi loaded Eclipse calipers, around $58 per.
Anything else I should be looking at?
thanks,
Rob
- checked the pins twice, lubed and free
- brake fluid changed when pads and rotors replaced
- front hoses changed in case they had collapsed
thanks,
Rob
