Recommended service | Ford Explorer Forums
Recommended service
322hunter
Noblesville, In
2001 Sport Trac
I just purchased a 2001 Sport Trac w/91K
I am getting the trans and transfer case serviced -should I do anything else?
Thanks,
Jeff
At 90,000, unless you know they were recently changed I would do the spark plugs as well. Check the condition of the coolant and other fluid levels too. Good luck with the trac, and welcome to the site. You will find tons of info on most all issues you may have. One easy way to learn is to look into old threads by using the search feature.
