A Wise Guy
- January 14, 2003
- McHenry, IL.
- '06 Limited Dark Cherry
If you had another temp gauge hooked up (or reading from a scanner) to verify the actual water temp is not too high, than I would say that your diagnosis is correct and that it is some sort of warning only.
Do you know if the V-8 has a rev limiter? (I would think all computers have a built-in rev limiter these days)
Not sure about the rev limiter. Look at the sheeeit I got for manually shifting an automatic trans and letting the tach touch red. I'm leaning towards an extra warning built in only because after about 10 seconds the guages are back to normal and there is no way to eliminate an overheating condition that quickly.
Bill and Bender thanks for sticking to the topic and asking for clarification when needed.
