thanatos9
- December 7, 2009
- Edmonton, Alberta
- '92 xlt
4wd is giving me fits. Winter is coming and I've exhausted ideas short of replacing the selector motor and computer which i don't want to spend money on. So I have a plan B. I want to remove the selector motor, weld a steel bar to the end of the selector "knob" on the transfer case, to which I will attach a cable and return spring which will be run up into the cab allowing me to manually select 4wd. But before I go and undertake this "repair" on my explorer I was curious if this generation had a manual 4wd option instead of the push button selection mine has. If it does I should be able to find this set up in a junk yard and just bolt it on. So how about it? Any stock, lever/cable/shifter actuated 4wd for this gen of explorer?
