Remote Start help | Ford Explorer Forums
Remote Start help
desitdt
Tallahassee Florida
2000 Explorer XLT AWD
So i got a remote start system : ReadyRemote Remote start DIY. I am having trouble wiring it up. I took off the panel under the steering wheel and seem to have the ingition cylinder harness. Can anyone confirm that this diagram for a 2000 ford explorer AWD XLT is correct?:
http://www.the12volt.com/installbay/...etail/864.html
Can somone take a picture of theirs and label each wire? Also it says it has three ingition wires but the third is the same (yes or no?) as the accessory wire. If i have three ignition wires i have to have an additional relay and if there is only two then ING goes into ING 1 on the brain, ING II goes to ING II on the brain, and ING III goes to ACC (accessory) on the brain. I need to know which way is correct. Thanks in advance!
