dogfriend
Human-Animal Hybrid
- July 22, 2002
- Carmichael, CA
- '97 Sport 4x4
Hi
I'm in the middle of replacing the rear speed sensor on the transfer case. (Its leaking).
The sensor wires go into a hard shell connector which also contains circuits for the shift motor and front sensor. The new part just has the wires with the connector pins that go into the shell.
How do I get the pins out of the shell? Usually you want to depress some tabs on the pin that lock into the shell. On these pins there arent any tabs, just a recess. The tab is built into the shell, but I can't figure out how to release it.
Thanks in advance for reply(s)
