remove both taillights and remove the small silver bolts in those spots under them that connects to the bumper then pull up on the bumper and it should pop out on either side... if u need anymore help ill try my best for giving advice
you cannot remove the running board w/o taking off the bumper. first take out the taillights. there is one screw under each one that needs to come out. after that you must take out about ten of those black clips that hold on the bumper by the weatherstrip. then under the truck at the very bottom where the bumper meets the truck there is one screw on each side. after that you should be able to lift up on the bumper where it meets the body and pull it off. be carefull not to let the bumper fall and rip the harness for the sensors. that should be it.
p.s. i tokk off my bumper, cleaned every contact and sensor, and it still doesnt work.
