ponkotsu
- October 29, 2012
- Colorado Springs, CO
- 2005 Lincoln Aviator
Got kind of a quandary. I have a Mounty with about 145k miles on it. Front end has a really bad left front hub and left upper control arm. Left hub is definitely already replaced at least once. Right side is tight as a drum even though the parts appear to be original. The left side is bad enough that I think it could be dangerous so it needs to be fixed asap. (About 3/8" in-out movement of the tire. And the ABS sensor is destroyed from the hub runout)
I've heard that both hubs should be replaced at one time because if one goes bad the other usually follows soon. But I've also heard that OEM hubs can often go 200k miles or more.
If money were no object, I'd just replace everything with Moog and Timken, but I have kind of a tight budget now. So I'm thinking about just installing service grade hub and UCA on the left side and worry about rebuilding the front end next year.
