Are you sure that the new seal is not just coated with rubber, and is steel inside? You could return it and get a steel type seal. If it is all rubber, I suspect that you were given the wrong seal. From your post I guess that you are working with the tapered roller wheel bearing, and not the spindal bearing that are needle bearings.
You certainly could reuse the old one if it is in good shape.
