- June 24, 2003
- Newcastle Wa
- White 94 Limited
- Callsign
- KG7PKQ
Glacier and Shamaal, have you guys heard of anyone replacing their evaporator core?
I've read about 50 threads on AC problems and haven come across ZERO requiring a new evap core.
I had my system worked on a couple weeks ago and the shop claimed that's where the leak is. They quoted $1200 for repair. (won't hold vacume etc)
I see a little oil residue at the bottom of the blanket surrounding the evap and there may be some on the passenger side floor mat.
I've read the evap box is attached to the fire wall with 3 bolts and there are 11 screws holding the box together. I think I saw 2 bolts and I suppose the third is hiding in a knuckle busting place.
I'm thinking of replacing the parts myself then taking it back to a shop to evacuate and recharge, since I don't want to buy a pump and guage set for a single repair if I don't have to.
My parts list so far;
Oraface tube
Accumulator
PAG-46 oil
NYLOG lube
AC/Fuel line DX tools
and of course the evaporator core, or should I hold off on the evap and replace the 'above' first, then take it to a shop?
Thoughts?
Oraface tube
Accumulator
PAG-46 oil
NYLOG lube
Thoughts?
