Replacement Bushings...I lost 1 side of Rear Sway Connect. | Ford Explorer Forums
Fischer
Durango, Colorado
95 Explorer XLT 4x4
I lost the bushings off the lower part of the rear sway connect. Does anyone know if these are sold as single units, to save me some $$..
Thanks
Or if you have some extras (those with no sway bars and poly bushigs chillin getting dusty)...
Thanks!
The entire endlink that hangs down from the frame is $12 from Ford.
I just lost the Poly bushings as well as the washers. They are the bushings that go into the drop down linkage. Same bushings top and bottom, I just lost the pair that go in the bottom part somewhere on Imogene Pass this weekend.
You can get them from Hank or autozone.Hanks Daystars are alot better :)
I just don't want to buy the whole rear end kit for 30 some bucks when all I need is 2 of the 8 that come with the kit.
I might have them two in my garage:D
Exactly what I was going after...
Awesome...I knew someone would have done the Poly Bushing mod then decided to take the whole thing off.
I have them are they the same for a 92 to a 95?:)
I have no idea:confused:
Well if they are you can have them:)
I'll get a picture of the others with a ruler then we can see.
Are those the Poly bushings. I am not sure if the difference is noticeable but I have Poly ones.
yeah they are polys I only had them in there about three weeks:)
NIce...I'll get those pictures this evening and I can post them tomorrow...
Off the subject...I really didn't notice THAT much of a difference after I took the bolt out (after 1 of the 2 bushings had taken a vacation). Just a bit more rolling on (madman) I-70 snaking through turns at 75mph+
