wimpytwins
- November 29, 2004
- utah
- 93 explorer sport 2dr
i have about 70,000 miles on a rebuild a4ld tranny. they front off the tranning was leaking fuild out as fast as it would go in so i pulled it out had a shop replaced the bushing and front seal and align it all up. when i opened it up to take of the front to take it to the shop the tranny looked like brand new. i didnt disasemble it at all but there was'nt any bunrned or build up of fluid or clutch plate material. i also droped the pan and relaced the filter.the bottom of the pan had a very layer of clutch plate material that wiped off with a single wipe.it though that wasnt bad for a rebuild tranny with 70,000 on it. i also bought a new tourqe converter. as i was putiing it back together i turned a knob on accident and found out it was a after market adjustale vancume modulator. i filled up the tranny with micron/decron 3.
now when ever i put it in reverse if i gas it a lot of gas the whole truck shakes. if a granny peddel it it works fine. in the forward gears it shifts though all the gears by the time it get to 30-35mph. i also can feel it slipping threw all of the gears. again if i put my foot down from a dead stop it will do up fine to about 10-15mph and then start to shift and slip bad until it gets into drive(i put the shifter into drive not over drive.) it works great after that. i can get on the freeway and no slipping i can also go into overdrive with no slipping. if i manually shift threw the gears my self there is no slipping when it shifts or once it is in gear. i have never had any problem before with my tranny and even when it was leking fluid pretty bad it still worked great. i have been slowly turning the vacume modulator in both directions and it just seams to make everything worse. can the vacume modulator cause all of my problems? what the hell is did i do?
thanks bryan
thanks bryan
