Reverse Gauges | Ford Explorer Forums
Reverse Gauges
kcar711
Clemmons, NC
'96 Sport 4x4
just do a search, you can find many threads on installation, I'm sure of that
I could even do though myself. Here is a thread someone wrote up with pictures. Read the whole thing and you will understand it even more. This is really not a hard install. And the ones you bought look like the plates slide right over the needles so you won't have to reset the indicators or anything. A piece of cake.
Dead Link Removed
Hope that helps. Let me know if you need anything else.
Thats a great write up but there again I've had some bad experiences wiring interior equipment. I didnt quite think it took so much disassembly to install a new cluster. I'll see what I can do.
Are the gauges for your 96 with or without tach? i'm having trouble finding reverse-glow gauges w/tach for my 96
I just finished that same install. Took about an hr or so total, just go slow and don't force anything. One thing I did different than the write up, It says to plug back in the cluster so that you can aline all the information lights, what i did insted was set the cluster on top of a lap shade so that I could get a better alinement. I also used hot glue insted of scotch tape, its got a better hold but can still be removed.
