Rich smelling exhaust and rough throttle | Ford Explorer Forums
Ocala, Fl
97 Ex E.B. 5.0 AWD
Hey I posted elsewhere but no responses.
I noticed my exhaust smells alot like gasoline and when I accelerate or open the throttle at idle I get a very rough response as in the engine shakes violently.
I thought it could be the O2 sensor but I'm not throwing any codes. Thoughts?
Sounds like you have a misfire. Check the spark plugs, wires and ignition coils.
Rough throttle
I just finished doing that a week ago. The person I bought it from had done it incorrectly and was running around with 7 of 8 cyliners firing. I'll go through and check again. And let you know.
check the fuel pressure regulator see if it is working properly,
you can check that by doing a fuel pressure check and pulling the vacuum line to see if it has a leak down condition,
Fpr
I had thought of that as well. I removed the vacuum line there was no fuel leakage or odor I could remove the whole thing but woul it be a pain.
Fpr
The FPR seems to be working correctly. The engine is still running rough. I think is O2 sensor but no codes. All cylinders firing from coil.
Update.
Okay I feel really silly. I bought this truck from a not very intelligent individual. He had already replaced to spark plugs and one wire. Well apparently he crossed the put the number 4 and 8 cylinder backwards. So I have been running on 8 cylinders and so had he...Oh man I swapped the two and now the truck is running like a champ. Also since then I've fixed his "5 min fix" for the blend door which he botched and replaced the shocks that I got for a deal from Amazon. In total repairs have cost me 200 including new blend door actuator, blend door fix from rockauto, and new shocks.
