road noise in speakers...? | Ford Explorer Forums
hazardiz
Prince George, BC, Canda
91 Eddie Bauer
I just put my new stereo in...Pioneer premier 540...pheonix gold 500.2 and JL e4300 for the speakers...3 ten JLw0's...all round 6.25 component VRs...and now when i turn the system on i get the squeel through the speakers from the gas pedal...i have my rcas on the opposite side from power and everything and i have ground loop insulators to take out the road noise and still it comes through...what could it be...please help...thanks...
u posted twice
I have the same problem, I thought however the seal on the speaker wasn't tight so it allows air through.
someone mentioned the fuel pump from an explorer can hinder noise into the speaker... im not sure about it though
Since the GLI didnt make any differnece, the noise brought into your system is most likely induced from either the positive power wire or the rca cables. There are various troubleshooting methods for this, including temporarily running a power wire outside the vehicle, from the battery to the amps, or running a temp set of rca cables outside the vehicle, as well. If the noise stops when doing either (hopefully not both), then you have found your culprit and need to reroute. Electrical noise is very tricky and frustrating, but take your time and try to get it taken care of correctly. Band-Aids often let you down over time. Good luck.
