FLOffroad
- July 8, 2009
- Wasatch, Utah
- Forester; 08 ST sold :(
Any ideas on the idea of using sheet neoprene rubber for flooring as opposed to the ever-popular Line-x. I was just thinking that using neoprene rubber could provide better sound insulation, and possibly better heat insulation than Line-x. It would probably cost about the same, if you DIY the neoprene rubber, depending on what grade neoprene rubber you choose to use. Also, you wouldn't have to worry about the gaps from tearing out the carpet because the neoprene rubber can be basically as thick/thin as you like, so if you chose rubber approx. as thick as the original carpeting, then the gaps from removing the carpet would be filled in by the neoprene rubber.
I don't think the neoprene rubber would look as nice (it's just smooth rubber), but other than that I can't see any real problems.
Also, they make "fire-resistant" neoprene rubber, which is resistant up to 250F, so I figured that could be used in the front near the engine for additional insulation.
Please comment - Thanks.
