Nick_R_23
- February 1, 2011
- Willow, Alaska
- 1950 Chevy 3100
Hey guys, I just picked up a 1998 Ford Explorer yesterday. Its a 2wd, 4 door, 5.0L, Eddie Bauer edition. The trans is out so I got it for only 600$. My plan is to remove the body, lengthen the frame a few inches, and use the chassis under my 1950 Chevy truck project.
Please forgive me if I have some really stupid questions here, I work mostly with Chevys, so some of this Ford stuff is new to me.
Originally, I was going to use a SBC/T5 on the Explorer frame, but the 5.0 still runs great, so I figured why not rebuild the 4R70W and use the engine and trans I already have, and save a few bucks over building another SBC?
I have done some research on what I have, and it seems the PATS system is hard to get around. I would have loved to find a base model 95-97 without the PATS or all the extra electronics, but 2wd Explorers are really rare up here. In fact, this one is the first one Ive ever actually seen, so I didnt really have much choice. Since this is going to be a fairly bare bones hotrod, I would like to get rid of all the electronics that arent necessary. Mostly the PATS, electric windows, ABS, A/C, console, etc. I have done projects like this before, so this is nothing new, I just havent dealt with Ford's computer setups much.
So what would it take to delete all the extra electronic junk and just have a stand alone running engine and working trans? I read that the PATS can be disabled in the PCM, but it seems like it would need to retain all the wiring still. It also appears that I would need to use the Explorer column and cluster, neither of which I plan to do. I also dont want to get into expensive stand alone/aftermarket wiring or EEC programming kits, as this is a budget project. Id like to make this work with what I have and what I can find in a junkyard.
From what Ive gathered, my options are:
Use what I have (98, PATS wiring), disable PATS from the EEC, and may or may not be able to eliminate the wiring. Seems like I still need the cluster and column to make this work.
Find a 95-97 (base model, pre-PATS) Explorer and rob the harness/computer from it. The problem seem to be that some stuff still runs through the cluster and column, and Im not sure how Id get around this.
Possibly convert to EEC-IV? Ive heard talk of this, but cant find much info. Seems like the major thing is lack of support for coil packs, so I would need to use a distributor. It also doesnt sound like the 4R70W is compatible here. Upside would be that its a more well understood platform, with much more aftermarket support than EEC-V.
Ditch the 5.0/4R70W idea altogether and just drop a SBC/T5 like originally planned. I tried to find someone that had swapped a SBC into an Explorer but didnt come up with anything. I figure it would be a pretty similar fit to the 5.0, so I dont think there would be any clearance or fitment issues here.
So what do you guys think would be the best way to go with this? I know there will be more bias to use the 5.0 as this is an explorer forum, but I dont want to get into something that will be more headache then its worth. Id rather just slap a carb on a SBC and call it a day, then try and figure out tons of workarounds on an EFI system that still might not work right in the end. Looking forward to your ideas!
