1998Explodasport
- July 7, 2009
- Brockton, Ma
- 2001 Explorer Sport
So I picked up a 2001 Explorer Sport with the SOHC. I have no history on it besides that it was submerged in fresh water up to the cup holders but I belive it was more than that.
So I changed the oil, siphoned all the gas out and replaced it with a half a tank of good gas, did a transmission filter and gasket and replaced about 6 qts of transmission fluid with Merc V (I am going to do a complete flush if I get it running). I had spark and fuel so I kept at it until it started and it finally did. It ran rough, which was expected. I ran it for about an hour and it finally idled by itself so I pulled it into my garage and changed the oil again and I had trouble starting it. I scanned it with mt scanner and got no codes but I also noticed that the engine light doesn't come on when you turn the key to acc. but it does come on a for split second as I try to start it.
I am thinking the computer may be bad, I just wanted to see if anyone had any ideas as to what I should do next. I was going to start replacing differential fluids but I want to get it running smoothly first.
