Seatbelt minder/chime goes off for 5 minutes | Ford Explorer Forums
mitch28
Burlington,MA
'03 XLT
Every time I get in the truck and start out,, the chime will sound for about
10 seconds every 30 second. This goes on for about 5 minutes. I've visually
checked the wires/connectors under the drivers seast and everything looks good. What do I try next? Thanks!
Mitch
Dont know if this will apply to your problem but i was working on my girlfriends explorer and one of the doors had a bad ground for the door ajar switch,are any of your lights staying on when you are inside of it?Id check the grounds on the seatbelt part,if there good maybe run a jumper from the seatbelt ground and make it ground somewhere else just to see if it stop chiming goodluck and hope this helps
