seatbelt minder chime wont shut off | Ford Explorer Forums
joshua8378
manton, mi
Hi I have a 2003 Explorer and it does not register when I have the seatbelt buckled and the constant beep is very annoying. Does anybody know if there is a relay or some sort of switch that goes bad, or if there is just a wire I could cut or splice together to make it go off. I cannot deactivate the minder chime like it says to do in the manual because it never thinks the seatbelt is buckled. It is the driver’s seat it is also an electric without heat if that makes a difference. Thanks in advance for the help
Josh
