greasemanicure
- November 1, 2006
- Burlington, NC
- 1996 4X4 4R->5R mod
The 96 Ex 4.0 Ohv 4wd has developed a serious vibration at highway speeds. It happens when going straight and clears up for periods of time after hitting a bump or making a turn. I'm going to crawl under for a look at tie rod ends for play. That seems to make the most sense. I put the front end up on the jack and there seems to be play in the right front wheel from side to side but no play in the vertical. I recently changed the right front hub assembly and rechecked things for proper torque. Any thing else I should be checking while I'm under there???
