Shocks for SOA | Ford Explorer Forums
Shocks for SOA
Ryan1
White Bear Lake, MN
94 XLT
When I do my Rear Spring over. What length shocks will I need to buy? Seeing as you get 5.5 to 6 inches of lift do I need to by 6 inch lift shocks?
Thanks
Ryan
Since your moving the shock mount and spring perch above the axle tube your stock shock length is the size required. Even though it appears you've lifted the rear end you actually relocated the springs and your suspension travel stays the same. Hope that helped.
