sick bronco 2 | Ford Explorer Forums
sick bronco 2
gsc
1990 bronco 2
hey guys this is my first thread on this forum i posted one on the explorer by mistake i have a 1990 bronco 2 2.9 4wd drive that is very sick. i have seen these symptoms on many of the threads hesitation low power like it loading up. There was a thread by thtanoyingguy that resembled my problem was wandering if he found a solution? I have replaced the tps,map sensor, plugs wires ,cap,rotor,module on distributor checked fuel pressure 40 pds at switch on and running and took the exhaust loose to check cats. Fuel pressure regulator was leaking into vacuum hose and it was replaced also. I am pulling my hair out with this thing. i know the tps was not working properly by ohms testing and the regulator was leaking fuel but neither changed the problem. Any help with this would be greatly appreciated
