Sliders to frame bolt recomendations | Ford Explorer Forums
5.0L96Exp
Ottawa, ON
96 XLT
Can anyone recommend an appropriate bolt to mount my sliders to the frame. There are 3 mounting points per slider with 4 bolts each (total of 12 bolts per slider). The slider-frame plate is 4"x4"x1/4" with another 4"x4"x1/4" backing plate (ie the frame is sandwiched). I think 12 5/16" grade 5 bolts should be more than enough (tensile and shear strength are about 4500 pounds). Any comments would be greatly appreciated.. Regards
You have to remember that the tensile and shear numbers are at static.
An Explorer sliding down and landing on a rock is hardly static.
While you do have 12 bolts per side, I still personally wouldnt go with anything smaller than say 1/2-inch bolts.
I'd recommend 5/8" grade 8 bolts and don't forget lock washers & locktite. All of my slider bolts are I believe 3/4" head grade 8 bolts with locktite. When drilling the frame rails, make sure not to drill any of the fuel/brake lines or anything else in the rails.
Indeed, nothing smaller than 1/2" will hold-up, and nothing larger than 3/4 is necessary. Anything in between will work well. Grade 5 will be sufficient, grade-8 will just be a little stronger.
-Joe
Thanks for the input guys. 1/2" it is..
